fast idle
Old Jul 16, 2004 | 06:47 PM
TUFFY's Avatar
TUFFY
fast idle
Hi I've got a 1980 f-250 with a 302 the problem is when you start it it races at full throttle doesn't make any differnce if you step on gas or not it has a carter afb 4 barrel carb on it what could be causing this? junk carb? thanks Dave
Old Jul 16, 2004 | 09:20 PM
91f250460's Avatar
91f250460
Will the idle eventually drop down or does the engine race until you turn it off?
T. Roberts
UFD Local 1147
Old Jul 17, 2004 | 07:11 AM
TUFFY's Avatar
TUFFY
it races untill you shut of the engine
Old Jul 18, 2004 | 09:12 AM
LWJ's Avatar
LWJ
Here are some options:
1) vacuum leak
2) Idle set improperly
Make sure you time it when setting the idle.
Larry
Old Jul 18, 2004 | 08:11 PM
TUFFY's Avatar
TUFFY
turned out to be the throttle cable was binding up replaced it and problem solved. thanks for your replies Dave
Old Jul 19, 2004 | 12:03 AM
bigbrown84truck's Avatar
bigbrown84truck
tuffy, just so u know the cables from autozone, advanced auto, and pep boys are junk for the trucks. i put one from pep boys on my 84 with the 300 in it and it bound up after 12,000 miles, i've heard of others with similar probs. i then got one at autozone and used it for 2 days til my new one came into the ford dealer, i put the ford replacement in for the new autozone cable and man could i tell the difference in the ford cable. i am just telling u this so u don't end up like me with a hung open throttle on a back country road at 10:00 at night.
Old Jul 19, 2004 | 02:11 AM
fellro86's Avatar
fellro86
That's good to know, I like to know that it is going to last and not leave me stranded somewhere hours from home or parts store.
