Patch Panel Fine Points
Old Jul 16, 2004 | 09:07 AM
jvmcc's Avatar
jvmcc
Question Patch Panel Fine Points
I'm getting ready to install new stake pockets on the bed sides of my 53. A question: should these pieces be primed prior to installation? I'm putting the new pockets back in by welding spots at the points where I drilled out the original spot welds. Can I count on the primer to find its way into all the cracks and crevices where there is metal to metal contact? Or, should I prime everything first? Does priming adversely effect the welding?
Old Jul 16, 2004 | 06:53 PM
sdetweil's Avatar
sdetweil
You should prime first, you'll never get a better shot.. There are weld THRU primers exactly for this situation, where you NEED to prime first.
Sam
Pokee
Jan 22, 2017 04:54 PM
cgrutt
2004 - 2008 F150
Mar 2, 2016 12:38 PM
cujo8
Paint & Bodywork
Sep 15, 2007 08:15 PM
rtcalabrojr
19
Nov 27, 2004 11:30 AM
sancochojoe
Paint & Bodywork
Feb 24, 2004 06:30 PM
