Do I Need New Radius Arms?
Old Jul 15, 2004 | 06:48 PM
Boss50's Avatar
Boss50
I took my radius arms out today to replace the bushings and when I put the new ones on I noticed alot of play in them. They didn't fit tight against the bolt. The bolt where the bushings go rusted away to 11/16 inch and the threads are 15/16inch. Do I need to get new arms now, and if so where can I get new ones? My trusty LMC catalog doesn't list them.
Old Jul 15, 2004 | 07:27 PM
bremen242's Avatar
bremen242
Ford used to carry them, but that was in 1999 when I last checked on them.. I think $175 a piece?
*edit* http://broncograveyard.com/products/cat/20/172
JBG has them used for $45 a piece..
are you sure you're not missing a sleave or something? I've never taken mine apart, but it seems like a 1/4" of rust is a lot, even for PA
Old Jul 15, 2004 | 08:20 PM
Boss50's Avatar
Boss50
45 apiece isn't too bad.....It looked like there was a sleave inside the old bushing but it turned out to be just chunks of rust in there. I'll put a picture of the arm in my gallery in a little bit, but it doesn't look like there should be a sleave.
edit: I put the pictures in my gallery, they're in their own gallery. I looked at them at broncograveyard and it looks like I need a new pair..
Old Jul 15, 2004 | 08:33 PM
bremen242's Avatar
bremen242
Looks like maybe they were ran too long with bad bushings.... hmm. hopefully someone that has changed there bushing will jump in.. I am about to change mine for the first time. F-250s are better
Old Jul 16, 2004 | 12:11 AM
mustange70's Avatar
mustange70
Do yourself (and the truck) a favor and go to the wreckers and get a set of i-beams, complete with the radius arms, with the camber/caster bushings in the topball jointand swap those in place of the old ones cause you'll be pretty well to the point of swapping the i-beams anyway and also you will be able to better align the truck as well.
Old Jul 16, 2004 | 06:58 AM
Boss50's Avatar
Boss50
I just realized that everything on JBG is for four wheel drives, I have a 2wd.
Old Jul 16, 2004 | 07:47 AM
Charles in AZ's Avatar
Charles in AZ
You should check to see whether the bushings you have are for the 2WD. As I recall, the radius arms on the 4WD have a larger diameter thread than those used on the 2WD.
