Sponsored by: Auxito
accessing engine codes
Old Jul 15, 2004 | 10:33 AM
cmchambers99's Avatar
cmchambers99
Recently the check engine light came on in my '97 f-150, the next day it went off again, so I though it may have somehow worked itself out. No such luck, a few days later it came on again and has been on since. Does anyone know the prodcedure for performing the self diagnostic and then a list of the codes to determine the problem? Thanks for the help.
Old Jul 15, 2004 | 01:03 PM
myke's Avatar
myke
if you have an autozone nearby, they'll read the code for you. post the code here & you'll get help.
Old Jul 16, 2004 | 09:17 AM
FourthFordTruck's Avatar
FourthFordTruck
Are you in a 4.6? There are several guaranteed problems that will occur, especially are 100,000 or so.
Old Jul 16, 2004 | 10:56 AM
cmchambers99
I stopped by auto-zone yesterday and as soon as I pulled into the lot the check engine light went off!! I decided to get it diagnosed anyway just in case the engine code was still in the computer. The code readout was P0133 which if I remember right is a slow oxygen sensor response or something like that. The guy at auto-zone said that I should try replacing the oxygen sensor first and see if that solves the problem. If not, he suggested that I may have to replace the wiring going to the o2 sensor. Would this be something fairly easy to replace myself or should I just take it into the garage? Thanks for everyones help. By the way fourthfordtruck, it is the 5.4 with about 60,000 miles.Thanks
Old Jul 16, 2004 | 11:24 AM
myke's Avatar
myke
Here's what it says for that code:
P0133-HO2S Sensor Circuit Slow Response (HO2S-11)
Contaminated HO2S sensor
Exhaust leaks
Shorted / open wiring
Improper fueling
MAF sensor
Deteriorating HO2S sensor
Inlet air leaks
I'm sure someone here will be able to give you more specific guideance.
