Sponsored by: Innova
radio colored wirers
Old Jul 14, 2004 | 04:02 PM
steph2's Avatar
steph2
Red face radio colored wirers
I have a ford sound 2000 type f d 2001 radio with 7 wirers. 1 yellow 1 purple
1 blue 1 red 2 black and 1 white which one is which
Old Jul 19, 2004 | 10:21 PM
Msp541's Avatar
Msp541
Are you replacing the radio to a new stock radio or aftermarket? If going aftermarket get yourself a direct harness that plugs directly into the back of the factory wiring its a breeze after that all wiring is labeled...
Good Luck!
Old Jul 23, 2004 | 03:48 PM
steph2's Avatar
steph2
It's a aftermarket so i thought i could wire with out the harness. as you look from the back it as two vertical rows of pins 7 on left and 8 on the right
Old Sep 9, 2004 | 02:40 PM
AeroPA's Avatar
AeroPA
Steph, save yourself a big headache. Go buy the wiring harness adapter. I did mine, and it was so easy, it wasn't even funny. Wired the adapter to the head unit, then just went out and plugged it in the factory harness, and I was done. Everything is marked, and it all goes together like a breeze.
