Bronco II Ford Bronco II
REAR LEAF SPRINGS(help)
Old Jul 14, 2004 | 12:58 PM
Aggie05's Avatar
Aggie05
Exclamation REAR LEAF SPRINGS(help)
I recently went to the salvage yard and got a pair of 91 ford Xplorer rear leaf springs, i went to put them on but i have a block on top of the axle and the pin in the center of the springs will not fit the small hole ontop of the block??
NEed suggestions quickly, i have to use my truck for work tomorrow but dont want to put my old springs back on. thx in advance
Old Jul 14, 2004 | 04:54 PM
Aggie05's Avatar
Aggie05
I finally got the right blocks and now im wondering does it matter which way the new leaf springs face? I dont see to much of difference, the housing where the nuts go inside on the ends might be a little different in size but besides that it looks identical?
Any ideas, inputs, suggestions?
thx in advance
Old Jul 14, 2004 | 06:25 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Cool
You need to turn the center bolt over in the springs off the X to work on your BII and the will fit only one way.
