No blinkers?
Old Jul 14, 2004 | 12:07 PM
Traxxis's Avatar
Traxxis
No blinkers?
So lastnight, I am driving down the road, turn my blinker on, and notice that my blinker gives me the solid light in the cab, so I just figure, "Okay, I have a bulb out" and continue on my way home from work, when I attempt to merge onto the highway, I turn my other blinker on, and notice that the OTHER one is giving me the solid light in the cab. So, being that this particular stretch is rather remote at this time of the day, I turn my lights but leave the parking lights on, and both sides are lit up. Then, I push my brakes, and watch both lights work in my mirror. Then, I turn the hazard lights on, and all four corners work??? What???
So I pull into the driveway, and check all the fuses in the cab, of course, they're all good. So I check in the distribution box, and once again, all good.
Any suggestions?? Nothing feels any differently in the column mounted switch.
Thanks.
Stan
Old Jul 14, 2004 | 12:10 PM
Vin 95's Avatar
Vin 95
Flasher relay,what year is your truck?
Old Jul 14, 2004 | 12:17 PM
Traxxis's Avatar
Traxxis
1991 XLT. Same one in my sig.
If it were a flasher relay, I didn't think the hazards would work? Also, if it matters or not, I don't have any trailor hookups on the back the coulda shorted out.
87 XLT's Avatar
87 XLT
Take a look at the wiring diagram for the turn signals & E-flashers & you will probably see that the only difference between the 2 circuits is in the multifunction switch. If thats the case you need a new multifunction switch. What are you driving?
Old Jul 14, 2004 | 12:25 PM
Traxxis's Avatar
Traxxis
1991 XLT Ranger. Same one in sig.
Hmm... wounder how much that'll cost.
Old Jul 14, 2004 | 12:27 PM
Vin 95's Avatar
Vin 95
I'd get one from the salvage yard for a couple bucks (I'm cheap,I know).
Old Jul 14, 2004 | 12:29 PM
Traxxis's Avatar
Traxxis
Thanks, I appreciate it. I'll go get my Chiltons manual and check it out. Where exactly would this switch be?? Under the dash I assume?
Old Jul 14, 2004 | 12:30 PM
Traxxis's Avatar
Traxxis
Same here, if I can get it from a salvage, I just may do that.
Old Jul 14, 2004 | 12:53 PM
87 XLT's Avatar
87 XLT
If your Chiltons shows that you only have one flasher to operate turn signals AND emergency flashers (like my 95 Taurus) then you need to replace the multifunction switch. If you have 2 flashers, just replace the turn signal flasher. Not sure when Ford went to the single flasher setup. FYI, the turn signal lever is attached to the multifunction switch.
Old Jul 14, 2004 | 01:08 PM
Traxxis's Avatar
Traxxis
Okay, great. So I would assume than that the switch is in the column?
Old Jul 14, 2004 | 01:18 PM
87 XLT's Avatar
87 XLT
Yes, it's in the column, but if you have 2 flashers, just replace the turn signal flasher as Vin95 said. I dont have a wiring diagram for a 91, but my guess is that it still had 2 seperate flashers.
Old Jul 14, 2004 | 03:45 PM
Traxxis's Avatar
Traxxis
Hmm... funny, they just started working. Didn't even do anything to it at all.
Thanks Guys!
Stan
Old Jul 14, 2004 | 03:48 PM
Vin 95's Avatar
Vin 95
Then he said "HEAL THIS RANGER" and it was healed.there was much rejoycing!
