Aerostar Ford Aerostar
Replace ball joints
Old Jul 13, 2004 | 05:38 PM
viag6's Avatar
viag6
Replace ball joints
where on the net can i find the procedure for chaiging ball joints on a 1993 Aerostar?
Old Jul 13, 2004 | 05:51 PM
copper_90680's Avatar
copper_90680
Upper or Lower? 2WD or 4WD?
Old Jul 13, 2004 | 07:02 PM
viag6's Avatar
viag6
Have to replace both, but more concerned with upper. 2WD
Old Jul 13, 2004 | 10:29 PM
Muffinman's Avatar
Muffinman
The uppers are easy. I assume you know how to jack-up and support a car. Remove the tire's, Support the lower A-Arm. loosen the nut and hit it with a large hammer or fork. You can grind the old revits off and just use a small punch to push the rest out. The new ones can be Bolted back in. Reverse the order to install.
The lowers you will need a jack to lower the A-Arm because of the spring.
Old Jul 14, 2004 | 05:18 AM
viag6's Avatar
viag6
Yeah, i have changed ball joints before, but none with rivets. Also, it looks like the rear of the ball joint is "clamped" in some kind of bracket with one bold on each side. what is that? do i unbolt those?
