91 explorer transmission replacement
Old Jul 7, 2002 | 06:02 PM
kell3238's Avatar
kell3238
Post 91 explorer transmission replacement
The tranny im running in my explorer i asume is the stock 4wld transmission but at 150k its really starting to struggle going into reverse and it slips bad when 4x4ing. is this the early sign of a new tranny? If so i want to put a better one in that can take more abuse so if anyone knows of one that would bolt up to the stock 4.0L that would really help. thanks.
Old Jul 8, 2002 | 12:02 PM
adbradley's Avatar
adbradley
As far as I know, the A4LD is the only auto tranny that Ford had for the 4.0...the 5 speed manual was even weaker than the automatic. Might try one of those trannys that the T-Bird Super Coupe had on the 3.8 but I doubt bolt patterns would match. Maybe someone out there has an adapter plate to make it work. Real cool...
Old Jul 8, 2002 | 11:31 PM
lew2002's Avatar
lew2002
