CE light goes "POOF"...!!!
Old Jul 13, 2004 | 08:07 AM
Mountaineer40's Avatar
Mountaineer40
Got a 98' Mountaineer AWD...161k miles. The CE lights has been on for about a year now. Got codes P401 ...something close to a bad O2 sensor. After hearing a very well -known local radio station talk about putting a full tank of BP Ultimate (98 octane) in to clean out the engine, I decided to do it. Guess what..the CE light went out and it has been out for a couple of days now and it runs alot smoother. Any suggestions as to why 1 tank of this type of gas would clear codes that have been present for over a year?
Thanks...
M40
Old Jul 13, 2004 | 02:43 PM
LV Dan's Avatar
LV Dan
Better gas has better detergents mixed with it. Usually the higher octane gas has more concentrated detergents in them. Perhaps this helped clean a sticking fuel injector, some sensors, or other deposits. If you run cheaper gas, carbon deposits will form quickly, hurting all those sensors.
Old Jul 13, 2004 | 03:31 PM
Mountaineer40
That's basically what I heard. But paying almost .50cents more a gallon can definitely hurt a wallet. When I had the injectors, spark plugs w/wires and belts replaced, the repair guy stated that the higher octane would keep the valves and injectors clean and save moeny in the long run. CE still out.."DEY IS A GOD" If I stay with the higher ( BP Ultimate ) octane gas, will it hurt the engine in the long run eventhough the manual states to stay with "regular"?
M40
Old Jul 14, 2004 | 04:20 PM
LV Dan's Avatar
LV Dan
I can't say whether running high octane is bad, bad I never do and follow Ford's recommendation of 87 octane.
However, I do run better gas such as Chevron, which adds Techron, their detergent formula. Chevron's Techroline is also available as a gas additive and have used it in all my fuel injected engines. I imagine BP has a good detergent additive, too.
If you search this forum, you can find lots of comments from other users about the higher octane gasses.
Old Jul 15, 2004 | 11:05 PM
Msp541's Avatar
Msp541
That sounds good to help get rid of the check engine light on my 1999 Mountaineer when i use the 93 octane it has a hard time starting in the morning and when using the 87 octane it starts fine, weird but i will stick to the 87 octane....
