Aerostar Ford Aerostar
Squeaking while AC running?
Old Jul 12, 2004 | 08:28 PM
agelder's Avatar
agelder
I'm thinking the AC clutch. Any other ideas. Only does it while AC is on, vent & heat are quiet.
Old Jul 12, 2004 | 09:39 PM
lasher's Avatar
lasher
mine made noise and i just shot wd-40 on it and the noise went away.
good luck
Old Jul 13, 2004 | 08:40 AM
moneyPit's Avatar
moneyPit
Mine was noisy too - I was also thinking clutch - I replaced the belt and it went away! - very odd.
Old Jul 13, 2004 | 10:26 AM
nibroc's Avatar
nibroc
agelder: I have a squeek as well when a/c is on I think if you turn off both fans you will see the squeek disappear as on my a/c. I think it is the added load on the alt. that causes squeek ( this would mean the alt bearings) . A good chk is to look at amp guage when it's squeeking and you will see a heavy load on alt. When you shut fans off, the amp guage goes into the normal range and squeek disapears.
Old Jul 15, 2004 | 12:14 AM
fifteen+'s Avatar
fifteen+
the added load is from the a/c compresser turning . check the belt and tensioner.
