Still Sputtering
Need help! Thought maybe too focused on control, & went to fuel. Replaced fuel filter and Fuel Press Regulator. Still no joy. The Chilton manual's schematics are incomplete. Maybe someone has a Haynes manual that shows the pinouts or wiring diagrams from the controller's connector to the gauges and/or the pinout wiring diagram of that big firewall feed thru connector. Pinning out the engine harness to controller connector as this gets posted.....
What controls 'droop'/load compensation? If the ECT senario smoked the controller, how will I know? Why was I put on this earth to be so frustrated with such a seemingly simple problem? hehehe..... Anyone know the starting fluid to check 4 vacuum leaks trick?
Any thoughts from anyone would be greatly appreciated....
'88 250, 351W, 4X4 if it matters..
