Multifunction or GEM?
Old Jul 12, 2004 | 12:08 AM
tx_harleygirl's Avatar
tx_harleygirl
First thanks to all that replied to my fuel pump relay question. I think its fixed.... (knock wood).
So, question 2. Another intermittent problem.. *GRRR* Sometimes when the windshield wipers or the windshield washers are turned on the radio shuts off for about 10 seconds and the comes right back on.
I was told by a couple of guys at work that it might be either the multifunction switch or the GEM module. Looking for opinions on where to start.
Thanks in advance for any replies.
94 Ranger 3.0
Old Jul 12, 2004 | 10:46 AM
rangerxlt02's Avatar
rangerxlt02
Just heard about a similar issue on talk radio yesterday.
This might be the GEM (I think it stands for General Electronic Module) that may have a loose connection or the plug harness is corroded.
Or it could be the ignition switch that is not fully engaging the sliders inside or is loose inside and causing it to not make a full connection.
I would start a search under the dash and see if any of the wiring\harnesses are loose or possibly there is a bare wire floating around that is grounding itself out.
HTH,
Scott
Old Aug 15, 2004 | 06:02 PM
remchoke54's Avatar
remchoke54
Smile GEM location
GEM stands for generic electronic module, and it is located behind the fuse panel.
So you have to remove the fuse panel to get to it.
Old Aug 16, 2004 | 01:18 AM
tx_harleygirl
Thanks rem, appreciate the response. I haven't dug into this issue any further, been doin some odds and end maintenance stuff on her that I've neglected . And..... the starting issue is still creeping up on occassion, but I think I've actually narrowed that down to the starter itself not fully engaging all the time. So, onward and upward, albeit a slow process.
Thanks for all of y'alls time. Back soon, I'm sure
Rockledge
17
Oct 30, 2015 08:19 AM
clymerl
Apr 17, 2015 08:19 AM
Monzter Kuztomz
Jul 18, 2011 11:18 AM
TimGinCentralNJ
Mar 15, 2008 04:20 PM
