Engine seized!
Old Jul 11, 2004 | 10:58 PM
AirSmitty's Avatar
AirSmitty
Unhappy Engine seized!
I was messing with my timing today. i retarded it about 1/8th turn and it wouldn't start. I put it back and then CLUNK! While I was cranking the motor over i hear a clunk, then my motor no longer turns. I got out and tried to crank it with a wrench. I found a remanufactured 390 for about $1200. If I got a non smog motor, would I have to run 91 octane? Theres also a 460 + E4OD in the truck trader for $1900, but that would end up costing more than 3000 from start to finish. I'm really po'd. How much would rebuilding my mill cost? Is there any other thing that would keep my engine from moving?
Old Jul 11, 2004 | 11:38 PM
Putt's Avatar
Putt
Check flywheel/flexplate bolts etc. in the bellhousing. Will it turn backwards? A non smog motor will not need premium fuel unless it has been built with more compression.
Hard to give estimates because we don't know the engines condition, but a stock rebuild without major head work will run ~$600, if you need major head work(valves, guides, seats) then ~$1000.
Old Jul 11, 2004 | 11:43 PM
fordeverpower's Avatar
fordeverpower
that doesn't sound right! i can't even think of why the motor won't turn over.
Old Jul 12, 2004 | 12:08 AM
EgoMan's Avatar
EgoMan
Check the starter the shaft may have turned in the housing or a loose connection it is possible. The stud can be turned loose while the nut is still on it and it will lose all connection. Hell the starter may be toast from all the trial starting....
Old Jul 12, 2004 | 12:14 AM
rusty70f100's Avatar
rusty70f100
Check the starter. I thought mine was locked up once, only to find that a starter tooth had broken and wedged itself in between the next tooth and the flywheel. Take off bellhousing dust cover, new napa starter, and it's good to go.
The clunk was probably the starter giving itself a wedgie.
Old Jul 12, 2004 | 12:18 AM
AirSmitty's Avatar
AirSmitty
I hope its the starter. $50 is alot cheaper than $1000. My starter has a warranty too... I'll check in tomorrow.
Old Jul 12, 2004 | 03:42 AM
fordeverpower
i never thought about it but it makes sense that the starter would be holding up the engine from rotating.
Old Jul 12, 2004 | 07:32 AM
EgoMan's Avatar
EgoMan
I had to go with that because it was the place I think nobody had looked yet.....lol He said wedgie....
Old Jul 12, 2004 | 07:12 PM
Ratsmoker's Avatar
Ratsmoker
I had that happen once. The starter locked the engine up solid. I couldn't even turn it with a wrench. Remove the starter and try to turn it.
Old Jul 12, 2004 | 09:47 PM
AirSmitty's Avatar
AirSmitty
Yup. You guys are right on. The gear on my starter was shattered into about 5 pieces. The starter has a lifetime warranty, hopefully I can apply. Thanks alot.
Old Jul 12, 2004 | 11:50 PM
Randyb12's Avatar
Randyb12
If you are getting your starters from Kragen's Definintly get the Autolite starter it is more expensive but worth it. I went through 4 of the cheaper ones before I upgraded. No problems since.
Old Jul 13, 2004 | 10:50 AM
2ndmouse's Avatar
2ndmouse
ive had starters jam the whole kick out gear in the flywheel and lock a motor up. I wasas upset asyou too.
if you hit the key and it went KLUNK before it even turned over I BET its the starter.
if it was turning over for a few sec and then went klunk, it still mighta broke off and got a wedgie, or something else I cant imagine.
good luck
Old Jul 13, 2004 | 01:37 PM
rusty70f100
Lol I've invented a new automotive term...
Old Jul 13, 2004 | 04:12 PM
EgoMan's Avatar
EgoMan
The starter wedgie
