C-6 modulator valve???
Old Jul 11, 2004 | 01:06 PM
ratman-73ford's Avatar
ratman-73ford
I was told to check the modulator valve on my 73 f100. How do I do that?????
Old Jul 11, 2004 | 08:21 PM
bosshoss's Avatar
bosshoss
Pull the vacume line off the valve itself, and look for wetness, or transmission fluid in the vacume line. You can apply vacume to the valve and see if it holds. If you change it, watch that you dont leave out a pin thats in the valve. I think its about an inch long. Some of the modulater valves could be adjusted. Its been a long time since i worked on them. Hope this helps.
Old Jul 13, 2004 | 06:17 PM
ratman-73ford
Thanks I'll give it a try
