Rear window? tail gate window wiring?
Old Jul 10, 2004 | 11:51 PM
martyhenry's Avatar
martyhenry
We replaced the moter to the tail gate window ... one thing the motor is good ... it doesn't work so it must be the wiring. Does any one have any kind of diagram or info ? The chilton don't help!!!!
Old Jul 11, 2004 | 12:52 AM
Dealford's Avatar
Dealford
Welcome to FTE!
While you're waiting for a wiring diagram, pull the connector off the motor & use a test light (with a real good ground) to check for power at the plug. Naturally, you checked the fuse/relay first.
Is there a separate ground wire in the connector, or is it grounded by the mounting bolts?
AL.
