Sponsored by: Auxito
Help! Front axle question
Old Jul 10, 2004 | 05:47 PM
JDW's Avatar
JDW
Gentleman,
I'm new to the forum but not to Ford. No experience w/ 4X4 front axles. I have a 99 F150 4X4 w/ a rotational noise that developed over approximately 1 weeks time. When I first noticed it(wife usually drives)I had to run to the store and noticed the ominous rum rum rum. Checked the fluid in front diff & found it down cople ounces. Now my question......What are your best guesses as to where the culprit most likely resides? I am not familiar w/ these front ends at all so I don't know where to look first. Any help would certainly be appreciated.
Old Jul 11, 2004 | 12:05 AM
kspilkinton's Avatar
kspilkinton
rum, rum? Sounds like normal harmonics, could be due to tire wear or bearings.... many different items make the sound I liken to a "warp" engine. Try rotating the tires to see if the noise changes.
Technical information on this front end: Ford factory 8.8", reverse cut, center disconnect (the vaccuum actuator for the front end is at the differential housing). It is a strange creature when you're used to dealing with old manual/ auto hubs.
If you've owned the truck for these past 5+ years with no maintenance on the front diff, then a few ounces is not much to worry about. It is probably about time to change the fluid (full synth 90W-140, iirc). It'll also give you an opportunity to look for wear in that area.
-Kerry
Old Jul 11, 2004 | 01:54 AM
Racerguy's Avatar
Racerguy
Hi JDW and welcome to the forum
Like Kerry said you should probably try rotating the tires and see what happens. If they are cupped they can make noise.
Does the noise change at all if you move the steering wheel back and forth? Usually if it does then you have a bad wheel bearing.
Old Jul 12, 2004 | 07:51 PM
JDW's Avatar
JDW
Hey guys,
Thanks for the replies. I'll definitely try the tires first. Doessn't seem to change with steering direction or in/out of 4X.
Thanks
Old Oct 10, 2004 | 08:32 PM
jharris's Avatar
jharris
Did that work? Mine is doing the same thing.
98 F150 4x4
