Starter and relay
Old Jul 10, 2004 | 05:35 PM
friedslacks's Avatar
friedslacks
Starter and relay
69 F-100 360 auto
Installed new starter (don't cha hate that top bolt). NOTE: I also might have problems with the relay (see below). The truck starts but I heard this aweful sound.. the starter gear banging against the flywheel gear (my guess)- I immediatley shut it off and freaked. Wrong starter from Kragan?? But REALLY how many different starters would fit on a 360? It bolts right up, nice and snug, no prob. Could just be a crappy one.
OR is the starter relay sticking in the start mode. I didn't recall hearing the starter running during the brief seconds before I shut the engine off.
Insights??
The long-winded part
A bit of background...
Got some bad fuel out here in California, probably Enron's fault (I know.. I'm mixing metaphors, it's just a joke). Truck wouldn't start. (same thing happened to my '70 BMW). Had to drain the tank, refill, and work the old gas out of the system. In the interim the starter gave out. Got the new one installed. While dry-cranking... the starter stuck on. Had to yank the battery cable to shut it down. Checked the ignition switch. Does not appear to be there. Removed the relay and bench tested (only a year old)- comparing its actions to an old one I had. Put the relay (newer) back on. No more starter on. WEIRD. No shorted wires. Everything seems normal. Then the above happened. The gremlin may lie in the relay or ignition switch. Any troubleshooting tips? Thanks
Old Jul 10, 2004 | 07:45 PM
Fritolay's Avatar
Fritolay
yeah ditch that relay its a pile if ti stuck shut once it will do it again. as far as that top bolt my little trick is to get about three long 3/8 extensions and just stand in front of the motor and turn that bolt. works great.
Old Jul 12, 2004 | 08:27 PM
baitmaster's Avatar
baitmaster
for sure, Frito, that relay will stick and keep giving that starter motor juice. They wear out or get dirt in them. Getting that cable unhooked will get your heart moving! Once had the same feeling when my '69 Cuda built 340 Six-pack had the carb linkage hang up WOT while on my way to 140 and beyond. Wheeee!!!
Csilcox
2009 - 2014 F150
Feb 25, 2017 10:05 AM
ZombieJames
1997 - 2003 F150
Aug 16, 2016 12:11 AM
taylerallen6
1997 - 2003 F150
Jun 21, 2016 06:45 PM
Jmschneider
Sep 14, 2015 10:10 AM
bradleyj
Electrical Systems/Wiring
Nov 12, 2006 08:53 PM
