1978 - 1996 Big Bronco
Running 2 batteries
Old Jul 10, 2004 | 02:23 PM
hoopsisliv1's Avatar
hoopsisliv1
Running 2 batteries
I want to run 2 batteries on my 1993 Bronco because i would like a better start and i also have a 12,000 milemaker winch. I was wondering how i would do this. I was thinking all i would have to do is connect both the negative sides to eachother and both the positive sides together and then from that hook up the truck and the winch. I was wondering if this idea would work, or just screw my truck up. Thanks
Old Jul 10, 2004 | 04:10 PM
WhëëlMå1's Avatar
WhëëlMå1
How about running an Optima battery, instead of using two? If you hook them up wrong, you can create a 24v current, and fry.....oh well just about everything shortly. I have heard good things about the Optima line, both with running accessories and for hard cranking.
Rich
Old Jul 11, 2004 | 12:48 AM
nelly781's Avatar
nelly781
yes, you are correct. i have the same setup in my truck. b/c if u connect pos to neg and then you will be creating 24 volts and thats bad. i almost connected it wrong myself. good luck to ya
Old Jul 11, 2004 | 01:27 AM
Breeze's Avatar
Breeze
Go to a junkyard and find the cables, left batt tray, etc from a diesel F series. As mentioned before, always double check your connections when connecting the batts. Also, the optima is an excellent battery (and works even sweeter when you have two!! :-) )
Old Jul 11, 2004 | 02:11 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check out this thread:
https://www.ford-trucks.com/forums/s...d.php?t=223897
