1978 - 1996 Big Bronco
No Spark or Fuel
Old Jul 9, 2004 | 10:34 AM
broncoman4x4xlt's Avatar
broncoman4x4xlt
Question No Spark or Fuel
OK so im on my second bronco now and im having the same trouble as i did with the last. I have a 91 ,351W. The starter turns over when you turn the key. Its not activating the fuel pump at all. I have replaced the fuel pump, the relays, and the ignition coil. The last time it ran we were hitting some woop dee doos and the positive battery terminal was ripped out of the starter solonoid. we replaced the solonoid first. We also found that som of the spark plug wires got diconected. And at the distributor cap the wires were not completely snapped on but they were some what connected. I have no power coming out of my coil it seems. The fuel shut off switch is down like its supposed to be and no fuses are blown. DOES ANYONE NO HOW TO FIX THIS. Im wondering if i need a TFI distributor module.
Old Jul 9, 2004 | 10:39 AM
Mil1ion's Avatar
Mil1ion
Welcome to FTE
As per the text near the title of the forum
No Tech questions on this forum.
I'll move this to the Big Bronco Forum for you.
Maybe take some time to see where everything goes
Old Jul 9, 2004 | 09:09 PM
BOJOFASO's Avatar
BOJOFASO
first off the battery is supposed to be held firmly in place with a battery hold down. if you had this properly installed you would not have ripped the wire out of the solenoid.
when you reinstalled the solenoid are you sure you hooked up the vehichle power wires to the right side of the solenoid? when the wires got ripped out of the solenoid did any of the fuselinks get torn and maybe they broke not giving power to the fuel pump and eec relas.
