General Automotive Discussion
Briggs & Stratton problems
Old Jul 9, 2004 | 10:27 AM
FORD352V8's Avatar
FORD352V8
Im having trouble with my tiller which has a briggs motor on it. I filled it up with gas and then about 10 minutes later it suddenly died. I am unable to start it no matter what I try. We are in the middle of a landscaping project and need it as soon as possible. Are there any common problems or issues with the 5HP briggs and startton motors? I am good at engine building but unfortaienly I am terrible at engine troubleshooting. Ant help would be greatly apperciated. Thanks in advance
Old Jul 9, 2004 | 10:30 AM
V10KLZZ71S's Avatar
V10KLZZ71S
Can you be more specific? Spark? fuel?
Old Jul 9, 2004 | 10:52 AM
94van's Avatar
94van
First, pull the spark plug and lay it on the head, yank the yanker and see if you get a good blue spark. If no spark, try another plug. Still no spark? Check the points if it has points.
If you have good spark, try some starting fluid in the carb. If it starts and then stops, make sure there is no water in the fuel, and the fuel is fresh.
That's the basics, lots of other stuff to check, but if I can't see and hear it, not much more I can do here on the board.
Old Jul 9, 2004 | 10:56 AM
BrianA's Avatar
BrianA
If you have spark, it sounds like you lost fuel supply.
Does it have an in-line filter? If so, replace it.
Does it have a primer bulb? If it does, does it fill when you mash it with your finger tip?
Any chance you have water in the gas? if so, try to drain the tank and refill and add a little fuel drier (like HEET).
Old Jul 9, 2004 | 11:34 AM
V10KLZZ71S's Avatar
V10KLZZ71S
If it has no spark,something ive seen many times is the flywheel key gets sheared slightly and it will not fire no matter what.It most likely fuel related though.
Old Jul 9, 2004 | 12:34 PM
wiseguy's Avatar
wiseguy
Does it run when the choke is on? If so, it's a fuel problem. Is the fuel tank above the carb or below it? If the tank is below the carb, then there's a good chance that the pickup tube has become clogged with lint, etc. Also, if the fuel tank is below the carb, check the diaphragm. If it gets a hole in it, no fuel will be pumped to the carb. The diaphragm spring can also be weak. But this won't apply if it's a nwere engine. The newer 5.5 HP Intek may or may not be configured this way. Your best bet is to check the fuel path. It's more than likely it has become clogged.
Old Jul 9, 2004 | 02:30 PM
FORD352V8's Avatar
FORD352V8
Hey guys thanks for the help. After some kicking and cursing I finally got it started. Its always run bad kinda misses and runs rough. Now that I think of it Ill bet the pickup tube is clogged or something because I think it uses engine vacum to pull gas out of the tank. Thanks again I didnt excpet so many posts. One more thing it is a single cylinder. The tank is below the engine. Another possiblity is that the line got some air in it and didnt want to fire. Next time it dies on me I will check all the stuff youall said.
Old Jul 9, 2004 | 02:50 PM
BrianA's Avatar
BrianA
Don't discount water in the gas. Depending on the slope you are on at any given time, the water (if there is any) in the bottom of the tank can slosh around and get picked up by the fuel pick-up tube.
If it were mine I'd clean and re-oil the air filter, then pour some gas drier in the tank.
Old Jul 9, 2004 | 03:17 PM
ranger429's Avatar
ranger429
The carb's on these small motor's get plugged with the smallest micron of dirt, they are very easy to clean. I myself would never use starting fluid, that is like giving the cylinder wall a real good bath, not good for those motor's.
The flywheel key is a common problem with these small motor's as well. If you pull the spark plug and have zero compression that is the 1st thing to look for.
Old Jul 9, 2004 | 03:27 PM
BrianA's Avatar
BrianA
Unless I'm baaaadly mistaken, it's a 4 stroke he is dealing with.
Old Jul 9, 2004 | 04:27 PM
MW95F250's Avatar
MW95F250
Carburetor Cleaner is a safer alternative to Starter Fluid. It does not thin the oil out like ether does, and is just as effective at starting a stubborn engine.
Spray some Carb cleaner in it the next time it acts up. If it continues to run bad, take the carb off and take it apart and soak it all in carb cleaner for 15 minutes, then put it back together, do not let the rubber or plastic sit in the carb cleaner for long, it will eat those up. If that does not solve it, get a carb rebuild kit from a Briggs dealer and rebuild it. That should be the worst case scenario.
