Holley 4180
Old Jul 9, 2004 | 06:55 AM
awiseguy's Avatar
awiseguy
Holley 4180
1987 f250 5.8 holley 4180 carb, when the truck is cold and under hard acceleration when I take my foot off the gas it backfires out the exhaust, even exploded 2 muffelers so far. it does not do this when truck is fully warmed up and only does it after full throtle. any ideas?
Old Jul 9, 2004 | 06:59 AM
pops_91710's Avatar
pops_91710
Yep, I'd say you may have a stuck power valve. Sounds like you are dumping raw fuel into the mufflers. Also....Check your float levels, see if one is stuck.
Old Oct 2, 2004 | 11:55 PM
awiseguy's Avatar
awiseguy
Problem solved, burnt intake valve on cyl # 3 Thanks
