Running Rich
Old Jul 8, 2004 | 08:16 PM
podman152's Avatar
podman152
Running Rich
I have a '84 f150 with a 2bbl 351w. It's been spitting alot of black smoke out lately and I'm wondering what I need to do. I checked the oil level and it's fine. I'm guessing I'm running rich. My gas milage sucks! Any suggestions?
Old Jul 8, 2004 | 11:28 PM
alcan60283's Avatar
alcan60283
Check your choke. Make sure that it is adjusted correctly. You could crobably use to lean the mixture some. Loosen the 3 screws that hold the coke housing on, and turn it counter clockwise some. NOT A LOT THOUGH. A little makes a big difference. Try that and see if it helps. Most likeley its choke related.
Old Jul 12, 2004 | 05:29 PM
Cole's Avatar
Cole
If you rev the engine does it run better ?
