frontend
Old Jul 8, 2004 | 11:33 AM
96xltf150's Avatar
96xltf150
Question frontend
I have a question that i am sure has been asked a million times, but here goes. when i back my 96 f-i50 up, the wheels leen in at the top. Anyone have the answer to this? I have replaved the bushings in the radius arms.
Any help would be greatly appreciated. Thanks in advance.
96
Old Jul 8, 2004 | 11:41 AM
oly1's Avatar
oly1
I have an 88 f350 CC LB that does the same thing. I sent it to the Firestone place down the road from the office to get it fixed. They replaced a drag link and two tie rod ends charged me over $300 and it is still doing it. Drives nice in forward no camber problems but back up just a few feet and it look bad, like this /----\. I think we have the same problem....
Old Jul 8, 2004 | 07:16 PM
96xltf150's Avatar
96xltf150
Sounds the same. All we have to do now, is get someone to tell us what is wrong.
96
Old Jul 8, 2004 | 07:23 PM
ATC_250SX's Avatar
ATC_250SX
Have you checked your pivot arm?? bushigs, the ones under the motor that holts the axle in place? if not the only other thing i can think of is springs.
Old Jul 8, 2004 | 08:26 PM
96xltf150's Avatar
96xltf150
Thanks, i really didn't give those bushings a thought. I'll check them the first thing in the morning.
Old Jul 8, 2004 | 10:33 PM
Egor's Avatar
Egor
I think it is pretty common, my 90 F250 does it also. I think it's because of the independant front suspension. Front wheels are slightly towed in, so when you back up it makes each tire try to pull away and forces down on the springs causing the / \. Not sure about the F350, shouldn't that be a straight axle?
Old Jul 9, 2004 | 12:59 AM
MustangGT221's Avatar
MustangGT221
It's because the radius arms are not designed to be strong going backward...they're designed to be strong when pushed upon (going forward). It's normal, dont' wrory about it mine does it too.
Old Jul 9, 2004 | 04:12 PM
ATC_250SX's Avatar
ATC_250SX
Yeah mine probly dose and i just dont notice, its just like when your stoped and turn hard one way and the front tips, and an f-350, it would be a straight axle with leaf springs, unless its 2 wheel drive. hen it would have the ifs i think,
