Speedo bouncing at 65
Old Jul 8, 2004 | 10:00 AM
Desieldummy's Avatar
Desieldummy
Question Speedo bouncing at 65
I'm wondering what would cause the speedometer to bounce up and down when diving at a constant speed (right around 65mph)??? It bounces 2 to 3 mph.
1996 Ford F350 Crewcab PSD
Old Jul 8, 2004 | 10:08 AM
dport's Avatar
dport
I have heard of similar problems when the speedo cable wears. You can try removing one end and applying a small amount of lubricant like graphite.
Old Jul 8, 2004 | 12:13 PM
Desieldummy
I thought all these new fangled vehicles were all computer controled??
Old Jul 8, 2004 | 12:54 PM
dport's Avatar
dport
I think there is cable that runs to an electronic sender. I am pretty sure that there is a mechanical component to the speedometer.
Old Jul 8, 2004 | 04:56 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
If I am not mistaken the signal for the speedometer comes from the rear differential. There is a vehicle speed sensor that plugs into the computer wiring harness. If this sensor goes out it could cause speedometer problems and anti-lock brake problems. That particular sensor has been known to fail before, but I wouldn't call it a high-failure item. Hope that helps.
Old Jul 8, 2004 | 05:18 PM
mekons0's Avatar
mekons0
I don't think the sensor on the rear diff is for the speedometer. I can unplug mine and the speedometer still works. I do get a antilock brake fail indicator on the dash but speedometer works fine. No idea where speedometer is picked up but would like to know. Any other ideas????
Old Jul 8, 2004 | 09:21 PM
dport's Avatar
dport
I am quite sure the speedometer "reads" off the transmission output shaft. The shaft is geared and on the side of the trans near the rear is a housing that holds a speedometer gear. A cable will run from there to the dash.
Old Jul 9, 2004 | 06:27 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
OK then-
If it's not the sensor on top of the differential then it has to be on the tranny. I just replaced my 97 E4OD and it's in the bed of my truck right now. There is no mechanical cable coming off of the tranny. The only other possibility is on the passenger's side of the transmission. There is a heat shield mounted there that hides a large electrical connector. It's about even with the back of the oil pan. I seem to recall reading something about a speed sensor being part of that plug but it might have been a turbine speed sensor for the torque convertor. Also, my truck is a 4x4, so maybe the reading is taken from the transfer case on my truck.
I hate being wrong so I'm going to do some searching and I will post my results back here. Maybe I can find someone who knows what they are talking about.
Old Jul 12, 2004 | 09:49 AM
Desieldummy
The tranny on mine was just rebuilt, I also changed the sensor on top of the differential.
Old Jul 12, 2004 | 11:31 AM
mstepchinski's Avatar
mstepchinski
I replaced my dash cluster on my 94.5, and there is **NO** cable back there - 4 or 5 electrical connectors.. Taking the dash cluster out was really easy..
Old Jul 12, 2004 | 07:34 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The VSS in the rear diff. is where the speedo gets it's reading. There is a tone ring mounted on the differential carrier and the teeth on that ring passing the magnet in the sensor is what the vehicle's speed is calculated from.
Old Jul 23, 2004 | 10:49 AM
mekons0's Avatar
mekons0
Lots of suggestions on the speed sensor being in the rear diff. HOW do you explain that the speedometer still works when that sensor is unplugged. I have a 6 speed manual and have looked all over it and find a sensor for the back up lights and 4X4 indicator but nothing else, not even one on the transfer case.
Old Jul 23, 2004 | 11:31 AM
mstepchinski
A question -
If you change tire sizes, how do you recalibrate your speedo to display the correct speed??
