390 3spd. *rate performance!
Old Jul 8, 2004 | 02:54 AM
Trail Master's Avatar
Trail Master
Who here has used a 3 spd. column shift with a 390? Will a stock 3 on the tree handle a 390? And rate the performance!
Old Jul 8, 2004 | 09:11 AM
rebocardo's Avatar
rebocardo
I hate manual column shifters so I would rate the performance low, besides that, they always seem to develop linkage trouble and the little plastic inserts/bushings wear out quickly and get sloppy.
Old Jul 8, 2004 | 09:14 AM
oldhalftons's Avatar
oldhalftons
the 303 3spd, will handle a 390 just fine
Old Jul 9, 2004 | 12:20 AM
bigric's Avatar
bigric
That's the setup I'm running and it's doing just fine. When the plastic bushings broke I used very short lengths of hose and it works great.
Old Jul 9, 2004 | 01:25 PM
Trail_Rider's Avatar
Trail_Rider
I had a 360 with a 3 speed with 3:08 rears. It worked just fine. Beautiful highway gearing, but no bottom end. I replaced the 360 with a 390 and other than no bottom end (burning clutches to get loads moving) it still handled the 390 with no problems. I finally replaced the three speed with a four speed to get some bottom end out of it. After putting the 4 speed in, I never had another problem with that truck.
Trail Rider
Old Jul 10, 2004 | 09:35 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
I have to agree,with Rebocardo... The 3 on the tree's go thru bushings..and there not a very positive shift.. The linkage bushings in the coluum arent worth the powder to blow them to ...you get the idea....
If they were so good..Why arent the on trucks today...? to many components to go thru..More components more wear..and a mushy shift...
Put one on the floor and feel how much more Positive it feels!-Russ
