Engine for towing
Old Jul 7, 2004 | 01:27 PM
prginocx's Avatar
prginocx
Engine for towing
I'm going to buy a 73 to 79 Ford truck for camping and towing my boat. Boat weighs about 2000 Lbs. I'm thinking manual transmission. Any pointers on which engine / model to avoid ?
I don't want a lot of power, but I do want a V8 hopefully a small block. Mileage doesn't matter. I'd like it to be reliable. I'll probably put a shell on it. Probably a shortbed.
Any info to steer me in the right direction ?
Old Jul 7, 2004 | 01:43 PM
F150daniel's Avatar
F150daniel
if you plan on towing don't get 302, anything but a 302, trust me i know.
check for cab floor and rear wheel well rust.
351W did not come factory in these trucks.
Old Jul 7, 2004 | 01:47 PM
73Custom's Avatar
73Custom
Any 73-79 will be good for you. All the engine choices are reliable and strong - just some are stronger than others. The 73-79s came with 300-I6, 302, 351M, 360, 390, 400 or 460 - depending on year and model. I have a 390 4v with a 4spd and love it. The towing ability depends a lot on the rear gears and how fast you want to go.
Do you have emissions testing in your state? Some 73-79s are exempt - might make it easier to own if it didn't need tested...
The options are different depending on the model. Some are 'plain jane' and others are loaded with a/c, power steering/brakes, tilt, cruise, ect...
A shortbed is a little harder to find, but most people prefer the longer wheel base for towing - just a thought.
Marty
Old Jul 7, 2004 | 03:55 PM
ranger429's Avatar
ranger429
Avoid the 302 and get the 351M. what year is it you are looking for? I would look for a 78 or 79, they hold some of the highest resale value (but if you are like most of us you will keep it till death do you part) and have a good combination with the 351M and a 4 speed, they are reliable, and you don't care about gas mileage LOL
Good luck finding a shortbed, they are becoming quite rare
Old Jul 7, 2004 | 05:23 PM
76supercab2's Avatar
76supercab2
I'd also go with an F-250 or F-350 for towing work. They have heavier duty frames, axels and brakes. If the boat is light (flat bottom aluminum with a 10 horse outboard) the F-150 will be fine but if you tow or haul regularly you'll be happier with the heavier truck.
Old Jul 7, 2004 | 05:31 PM
neverenough's Avatar
neverenough
IMO, your better off with the 300 inline 6 than a small block. Otherwise, the 351m/400 or 360 would be a good choice too. Parts are usually a little cheaper and easier to find for the '75- '79 trucks. Plus, they have factory electronic ignition. Better in the long run than the older points system. Unless you plan on hauling a slide in camper or camper trailer, the F150 should be enough.
Old Jul 7, 2004 | 09:18 PM
Dreampiper's Avatar
Dreampiper
later years also have better power steering and front disc brakes...
Old Jul 7, 2004 | 10:13 PM
zwinstead's Avatar
zwinstead
I have a 1977 F-250 2wd with a 408 (400 bored .030), Holley 650 4-barrel, Edelbrock Intake, Headers, 2.5 inch exhaust, Comp Cams 268HE, 4-speed, 3:31 geared Dana 61 with 265/75-16 street tires. This truck pulls great!! I have pulled roughly 6500 pounds with no problems although that is about the limit with my high gearing. When I am empty I can run down the road at 2650 RPM at 75 MPH. This nets roughly 12 mpg. I love the combo. With 4.10 gears I would not be afraid to hook to 10k pounds although that grossly exceeds the factory tow ratings, which I feel are weak.
Good Luck
Zac
Old Jul 7, 2004 | 10:46 PM
biz4two's Avatar
biz4two
Arrow
As others have said, try and stick with the later years (76-79). Of course the '76 was the last year the FE's were offered (360 & 390). Also, not to worry if you find a truck that has the 390 in place of the original 360...as that is a very common upgrade. I suppose you can tell that I am pushing more the FE family...but then I have a '76 F-150 4x4 with a 390FE in place of the original 360. Love the low end torque this engine puts out. Ideal for work/towing needs.
From personal experience, towing 2000 lbs...is really "NO" problem with my setup. So you should be totally fine in a F-150.
Good luck with whatever you choose...and enjoy your new FORD!
Old Jul 8, 2004 | 03:57 PM
JohnT's Avatar
JohnT
Smile
Your best engine choice as far as towing ability would probably be a 300 I-6, but since you prefer a V8, a 351M or 400M would be a good choice. You may have trouble finding a truck with a manual trans as automatics seem much easier to find in the 73-79 trucks. Also, the shortbed is going to be VERY hard to find. You would probably be better off with a longbed for towing and camping purposes anyway.
Old Jul 8, 2004 | 08:13 PM
zwinstead's Avatar
zwinstead
Johnt, why do you say the 300 I-6 is the best for towing? I have a 77 f150 Trailer Special with a 460 and I guarentee it would tow circles around any 6cylinder......
Old Jul 8, 2004 | 08:44 PM
brad76f250's Avatar
brad76f250
well i own a 76 f250 with a 390 4v. i bought it from a guy that towed a boat. i dont do any towing but do alot of hauling in the bed.
however its only a 3 speed auto. gets good low end power tho.
did a camper special come in these years? my dads older greater model was n f250 custom camper special. came with some 4.10s and a posi.
the I6 is a good towing engine.
Old Jul 9, 2004 | 01:03 AM
hotrod61287's Avatar
hotrod61287
Hey I Thank 302 Will Do U Fine
Old Jul 9, 2004 | 01:08 AM
Hardcore4x4er's Avatar
Hardcore4x4er
go with a 351m with a np435 tranny a stout combo and has served me well in hauling buddies race care for about 5 yrs and still kicking
Old Jul 9, 2004 | 10:58 AM
F150daniel's Avatar
F150daniel
thread about swaping a 302 into a 78-79 bronco.
http://www.broncotech.com/cgi-bin/ul...c;f=1;t=009428
