Cobra Intake
Old Jul 7, 2004 | 12:57 PM
Blue94-302's Avatar
Blue94-302
Cobra Intake
Hi, I am a brand new member. I own a 1994 F-150 4x4 with a 302 and E4OD. The truck has a Cobra upper and lower intake on it (offset circular ports). The truck runs great at high RPM and with the throttle in the floor, however I would like more low end power. It has a stock cam and heads. The truck also has a 3.55 gear. What would be the most bang for the buck? Is it worth tampering with the motor or should I just stick a 4.10 in the rear. Any other suggestions on making the most of the Cobra Intake?
Old Jul 7, 2004 | 08:25 PM
Matts72's Avatar
Matts72
That High RPM power really doesn't have much to do with the intake, but more to do with the high revving 302.
Switching to a 4.10 gear will bring your RPMs up at lower speeds. There really isn't anything else you could do short of recamming, or stuffing a W in there.
Old Jul 8, 2004 | 06:18 AM
Blue94-302's Avatar
Blue94-302
Thanks for the response, what is a good low end cam for a 302. It seems most of them are for higher RPMS.
Thanks
