Please Help, need info. about a TSB
02-8-2 APR 02 A/T - Slipping/Delayed Engagement/DTC P1762 Set
Can anyone tell me anything more about this? I have a 99 explorer, 4 door, and I have a little automatic transmission slipping now and then. It is only when the car is warm and happens one time. When I am driving away at a slow speed it seems to pop in neutral and then "catch" into gear. It drives just fine afterwards. My factory warranty expires next week so I would like to see if I could get something done this week yet.
Anyway, here is the beginning text from the TSB:
"A/T - Slipping/Delayed Engagement/DTC P1762 Set
Article No.
02-8-2
04/29/02
TRANSMISSION - 4R44E - 4R55E - 5R44E - 5R55E -
LOW LINE PRESSURE READING AT WIDE OPEN
THROTTLE (WOT) - SLIPPING SHIFTS AND/OR
DELAYED ENGAGEMENTS - POSSIBLE DIAGNOSTIC
TROUBLE CODE P1762 SET - VEHICLES BUILT
BEFORE 9/15/2001
FORD:
1995-2001 EXPLORER
1995-2002 RANGER
1996-1997 AEROSTAR
1999-2002 EXPLORER SPORT
2001-2002 EXPLORER SPORT TRAC
MERCURY:
1997-2001 MOUNTAINEER
ISSUE
Some vehicles built prior to 9/15/2001 may exhibit the following shift and engagement conditions:
^ Low line pressure readings while in DRIVE at
WOT
^ No 2nd gear
^ No 3rd gear
^ No engine braking in Manual 1st
^ Slipping shifts and/or delayed engagements
This may be caused by improper pressures controlled by the Transmission Main Control assembly.
ACTION
If the conditions described are verified, the Main Control may need to be updated to the latest level or completely replaced. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
NOTE THIS ARTICLE DOES NOT APPLY TO ANY OTHER CONDITIONS OR COMPONENTS THAT MAY CAUSE SIMILAR SYMPTOMS AND IS ONLY WRITTEN TO COVER THESE SPECIFIC CONDITIONS.
NOTE AN IN-LINE SERVICE FILTER IS NOT REQUIRED TO BE ADDED OR REPLACED FOR THIS TSB.
Verify that one or more of the following conditions exist:
^ Low line pressure while in Drive at WOT
^ Slipping/delayed shifts
^ Slipping/delayed engagements
^ No 2nd and/or No 3rd gear
^ OD Band failed OFF
^ DTC P1762 set
1. Verify that one of the conditions listed above exist with the vehicle.
2. If the condition exists, drain the transmission fluid from the pan.
3. Remove the fluid pan and fluid pan gasket, discard the gasket. Refer to Workshop Manual, In-Vehicle Service, Fluid Pan And Gasket Procedure.
4. Inspect the fluid in pan for major contamination.
a. If major contamination IS present, refer to Procedure A, to replace the Main Control Assembly.
b. If major contamination is NOT present, refer to Procedure B, to Update the Main Control Assembly.
5. After completing procedure A or B, verify the condition has been corrected.
6. Clear all DTCs. "
