2.9 Injector rail removal
Old Jul 6, 2004 | 08:16 PM
1 TON's Avatar
1 TON
Question 2.9 Injector rail removal
O.K. How the @#&& do you get this *$^! thing off ? I've tried the "rock it gently from side to side while pulling up" approach with no luck. These injectors are so close together at opposing angles I don't see how the injector rail is supposed to come off.
Unless this thing is supposed to come off as a single unit injectors and all, there is something I'm missing. Or you just pull like @#&&.
Old Jul 8, 2004 | 08:14 PM
Elfasto's Avatar
Elfasto
Question
Hate to sound like an *********, but did you pop off the clips that keep the injectors locked on to the fuel rail? I missed those the first time I tried to pull the injectors off when replacing mine.
Old Jul 9, 2004 | 08:55 AM
1 TON's Avatar
1 TON
Hey no problem, and yes I did remove the clips. I finally gave up and took it to the machine shop with the block. The machinist had the same reaction I did. This thing should just pull off but it won't. Supposed to give him a call back today.
Thanks.
Old Jul 9, 2004 | 07:05 PM
Elfasto's Avatar
Elfasto
Maybe try some silicone spray and alot of wiggling back and forth. They may work loose. WD-40 may make the o-rings swell up and make things even harder.
Oh, and I found Vaseline is excellent for lubing the 0-rings when re-installing the injectors.
EDIT:
I know I'm going to hear some crude jokes about me, Vaseline, and "slipping the injectors in" and whatnot. Go for it. I've heard them all.
Tim Hodgson
19
Mar 30, 2019 07:40 AM
sammy76
May 6, 2016 04:13 PM
WhiteBeast-05-powers
Feb 22, 2016 09:29 AM
Talltruck
Oct 26, 2015 11:09 PM
navistarnut
Sep 3, 2015 11:08 PM
