Bigger alternator
Old Jul 6, 2004 | 06:49 PM
brett_d's Avatar
brett_d
Bigger alternator
Is there a higher output alternator option for a 1976 F-250 4x4 with a 390, aftermarket or other model or year?
Old Jul 6, 2004 | 07:01 PM
battered_bronco's Avatar
battered_bronco
sure what kind of load are you running
big amp/aletric fan/water pump? a 130+++amp G3 can be made to fit
or
i got a NEW 85amp chrome old skool exernal fan bolt in no wireing or grinding from a ebay seller in san deigo can look up his ID if you like i am happy and only cost 10-15 more than the ~70 amp from autozone
Old Jul 6, 2004 | 09:08 PM
mhg's Avatar
mhg
all factory alt are the same other than regulator style ( internal or external)
up to 105 amps
you may have to have the pets man look at a differant model
best is to go to a shop that specializes in alt and starters to buy one
Old Jul 7, 2004 | 09:12 AM
beartracks's Avatar
beartracks
Check with PowerMasters for new large size units.
Old Jul 9, 2004 | 11:50 PM
battered_bronco
/\ya reread the question yet mhg/\
well there are the old external fan type in 5 1/2 and 6 1/2 inch case
the older style generator i know little of these but they are not benificial sooo
i assume there was a G1 alternator if it went to production who knows
the G2 was very problematic from what i have read
the G3 is readily availbe and can be retro-fit into older models ingeneral have seen upto 300 amp models
the G4 is the latest i believe and can not be easily retro-fit
and furthur each alernator had different mount options some mid to late 80s alts will "bolt in" to a 60s car or 70s truck others will not i just look at them
a a G3 with 180 degree offset mount tabs to bolt to mine i ground off apx 3/16(this may vary) off the upper tab(oposite of the pulley side) and reamed the hole slightly to accept the bolt ..ran a 8 guage wire to the starter relay and attached the ammeter lead not that hard or you can get a plug from a junk yard tell them what ya want or new ones are make
alas <<<brett_d>>> i re-ask...how much of a load (what extra eletrical equipment) have you added to the truck??
Old Jul 10, 2004 | 01:48 PM
ivanribic's Avatar
ivanribic
I bought a 200 amp alternator from an ebay seller by the name of motorcityreman. It cost me $220 but if you want to get crazy with the electrical stuff this is the way to go. They offer lifetime warranties too. If you're interested here's a link to his Ford alternators: http://stores.ebay.com/Motor-City-Re...isplayZ2QQtZkm If you don't see what you're looking for e-mail them and they'll get it put together. Their alternators are internally regulated. Just a word of warning though, if you go this route, be SURE to upgrade your alternator to battery cable to something a little heavier. If you don't it'll melt right off of there.
tinaheels
Electrical Systems/Wiring
Jan 6, 2009 06:28 PM
Americanmadeford
1983 - 2012 Ranger & B-Series
May 15, 2008 05:54 PM
NorthPac
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 13, 2006 09:09 PM
CustomCab4x4
Jun 26, 2002 10:03 PM
