Sponsored by: Auxito
2003 split bench in 1997?
Old Jul 6, 2004 | 01:52 PM
lorne961's Avatar
lorne961
Question 2003 split bench in 1997?
I see the forum is called 1997-2003 f150, so does that mean a split bench from a 2003 could replace the bench in my 1997 f150? The 2003 is a standard cab and mine is an extended cab if that matters. Thanks in advance for any help with this matter.
Old Jul 7, 2004 | 08:21 AM
Racerguy's Avatar
Racerguy
It should bolt in without any problems as long as the holes are already drilled in the floor. If they arent then you might have to drill a couple.
