using transmission fluid
Old Jul 6, 2004 | 09:33 AM
PRyan1983's Avatar
PRyan1983
my 72 f100 with c6 uses about 1/2 a quart in a week. there are no leaks. what could the problem be? the fluid is very clean and i keep the fluid level right on full. thanks.
Old Jul 6, 2004 | 12:55 PM
banjopicker66's Avatar
banjopicker66
Pull the vacuum hose from the modulator on the back of the transmission. It connects to a vacuum source on the engine. If it is wet on the inside with transmission fluid, you are sucking it up into the engine through a bad modulator.
It is an easy and cheap fix, too.
Old Aug 6, 2004 | 10:00 AM
PRyan1983's Avatar
PRyan1983
i replaced the modulator and it fixed the problem for a couple weeks. now it's using fluid again. it's using about the same amount it used to. what do i need to do?
Old Aug 6, 2004 | 10:18 AM
banjopicker66
Check the new modulator for a leak again. If there is transmission fluid in it, then either you got a defective new one (not impossible), or there is something wrong internally which ruinged the new one.
Or, you have a leak you haven't found yet.
Other than that, I am not familiar enough with transmissions to help out.
Old Aug 6, 2004 | 10:24 AM
BB's Avatar
BB
Has your engine backfired at all? Sometimes the pressure can rupture the diaphragm.
Old Aug 7, 2004 | 09:14 AM
PRyan1983's Avatar
PRyan1983
no, but sometimes when i start the truck it might make a small sputter kind of like a backfire. it runs just fine.
