Sponsored by: Real Truck
Super Duty Side Step Bars
Old Jul 5, 2004 | 11:48 PM
3speed's Avatar
3speed
I've got to install some side bars on a new 04 F550 4x4. In reality...Ford should include some standard as this truck is quite tall. I'm 6'-0" and actually don't like running boards or nerf bars of any kind...but this is a true case where they are needed to get in and out without jumping or pulling the heck out of the steering wheel.
Ford has two types in their accessories list. They have the right look and I'm sure they fit fine but they are a little pricey.
I bought some 3" diameter stainless ones with a pressed section where the plastic step pad goes. That supposedly makes them stronger. However they had some problems. Two screws holding the plastic step pad on were tightened down too much pulling them into the plastic. I can't get them out. No biggie. But it came with two passenger side front brackets so I can only mount one side for now. Then...the terrible installation photos didn't help me determine much. I can tell what they intend me to do sort of...but the holes in the brackets simply are way off the factory holes in the rocker panel. The rear brackets have some kind of bracket with two bolts welded to it and they simply can't be installed w/o drilling. The instructions says no drilling required...so I'm ain't drilling nothing. I didn't want to anyway which is why I bought these from the local truck place. They are going back.
Who makes some sturdy ones that actually work? The lower they ride...the better. I actually like the Ford oval steps but they are $450 which is kinda steep. True running boards are out of the question for me. Thanks for any input.
Old Jul 6, 2004 | 12:18 AM
jasonlasvegas's Avatar
jasonlasvegas
running boards
try the cabelas site they have running boards for $300.00 less shiping
