truck smoking
Old Jul 5, 2004 | 09:33 PM
killerman's Avatar
killerman
Angry truck smoking
I have an F250 1989 7.3 IH engine around 180k miles. It started smoking under a load and sometimes when I start out for about 5 miles. This is not normal smoke, this thing looks like a mosquito fogger. I replaced the glow plugs and injectors with rebuilt ones (6 from ford and 2 from autozone) and its still doing it. This is gray or black smoke and the engine detonates when it does it. The truck uses alot of oil about 1 qt per 100 miles and Im sure thats rings but it runs like a top so Im willing to put the oil in it. However the smokes got to go. Is this an injector pump?( If so wheres the best place to get one) or did I get some bad injectors?
Old Jul 5, 2004 | 10:09 PM
Dave Sponaugle's Avatar
Dave Sponaugle
How is the air filter?
Did it start doing this after changing the air filter, you may have a bad one.
A clogged air filter will do the same thing.
How is the fuel filter?
The return line crimped or blocked will also cause this.
If you have a diesel injection service close by they can pop test the injectors.
