Modular V10 (6.8l)
Engine Fault Codes?
Old Jul 5, 2004 | 12:05 PM
2 cowpokes's Avatar
2 cowpokes
Engine Fault Codes?
I have a 1999 V10 which shows engine fault codes of P0171 and P0174. Can someone tell me whats faulty or what is broken?
Thanks for the help...
Old Jul 5, 2004 | 07:23 PM
jcrice's Avatar
jcrice
P0171 - Fuel System Too Lean
Are you sure about the PO174 code? I can't find it.
Old Jul 5, 2004 | 07:26 PM
jcrice's Avatar
jcrice
Oh... PO171 is bank A, PO174 is bank B. Since it's both sides, I wouldn't expect an O2 sensor problem, but I've been wrong before. More than once, even.
Old Jul 5, 2004 | 07:27 PM
f4rhino's Avatar
f4rhino
<TABLE width="100%" border=1><TBODY><TR><TD class=ital width="10%">P0171</TD><TD width="90%">System Too Lean - Bank No. 1</TD><TR><TD class=ital width="10%">P0172</TD><TD width="90%">System Too Rich - Bank No. 1</TD><TR><TD class=ital width="10%">P0174</TD><TD width="90%">System Too Lean - Bank No. 2</TD></TR></TBODY></TABLE>
Old Jul 5, 2004 | 10:05 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Lean bank is a vacuum leak, leaky intake tubing, anything adding more air AFTER the MAF. Or, possibly a dirty/faulty injector - check the simple things first, cracked intake hose, PCV hose, bad PCV valve?
Also, I've had a '96 t-bird 4.6L with OBD II throw the Bank 1 lean code with a dirty MAF - take out the air cleaner, look down the tube at the MAF wires. If they are WHITE they are clean, if they are grey or darker they are dirty. Clean 'em up, and the MAF will start registering the correct amount of air (dirty will tell the computer less air, which is wrong, so the computer will see the engine running lean at the O2 sensors).
Seen cars with stock air filtes with dirty MAF's after only 20K miles... (GM, but hey...)
Old Jul 5, 2004 | 10:08 PM
Fixxxer14's Avatar
Fixxxer14
My 01 Olds Aurora will throw that code if I put anything other than premium in it. However, since these beasts only take 87, that's not your problem; I guess it could be bad gas though.
Old Jul 6, 2004 | 01:10 AM
keith w's Avatar
keith w
I agree with this since it is setting codes for both banks, a vacuum leak is where I would start looking.
Old Jul 7, 2004 | 11:24 PM
2 cowpokes's Avatar
2 cowpokes
thanks for the help
I want to thanks all of the respondants. It turned out to be a vacuum leak in the pcv hose. I fixed it and all is well. Thanks again, Wayne
