2005 Towing Guide???
Old Jul 4, 2004 | 01:06 PM
markha's Avatar
markha
Anyone seen a link to the 2005 towing guide yet? I know there have been some info but I was really looking for the specifics... max 5th wheel towing for the f350 4x4 PSD, Auto, Crew, SRW, 8' Box.
Thanks,
Mark
Old Jul 4, 2004 | 09:22 PM
Catfish_Man's Avatar
Catfish_Man
If you dig around on the Ford site I think you can't find an actual rating on a 5er pin weight or list axle ratings for the truck you inquired about. Haven't seen a tow guide yet for the '05. However they do have dimensions and capacities PDF available:
Here goes for the truck you listed:
(Pounds)
Base Curb: 6495
GVWR: 11400
Max Payload: 4100
GCWR: 23000
Maximum Trailer/Hitch Ratings:
Max. Tounge weight (Conventional or weight dist.): 500
Conventional Towing: 5000
Conv. Weight dist: 12,500
5th wheel/ gooseneck: 17000
From the above, you should be able to do a little math for getting real close to what you are looking for based on your 5th wheel.
Looks like you could drop about 3400 of pin in the bed and have 700 left for fuel, passengers and gear. (3400 is 20% of 17000 which is a guess as far as actual pin weight is concerned.) But I'd expect you would have all you wanted and then some on a SRW with 3400 pin weight.
Note: They say the SRW 350 tires will be LT275-70R18-E on the 4x4. I expect the low tire profile will help lateral stability when towing a heavy load quite a bit.
Ford has increased their tow ratings. According to a "salesman" they are getting more liberal with their ratings to better represent themselves against the competition. (Never trust a salesman!) On the other hand, Ford says clearly in in their literature that they they are putting in an "upgraded" solid rear axle. What that means is anybody's guess.
Maybe I gave you something you did not already have, Maybe not???
JCount
Dec 8, 2016 10:21 AM
dougert7
Sep 10, 2015 10:15 AM
Danner's Diesel
Jun 21, 2015 12:52 PM
DIYiT
All Things Towing
Dec 15, 2014 07:59 PM
4mulastv
1997 - 2003 F150
Feb 24, 2014 09:59 PM
