rear axle?
Old Jul 4, 2004 | 11:44 AM
3headedboris's Avatar
3headedboris
rear axle?
I have a 1964 F-100. I was wondering how do you tell which rear axle you have? Does the VIN # tell you?
Thanks for your help.
Old Jul 4, 2004 | 01:26 PM
banjopicker66's Avatar
banjopicker66
The Warranty Plate has a rear axle code. Post it here, and we can decode it for you. Be sure to post the entire series of codes; they often were not where they should be on the plate and the sequence occasionally has to be used to figure out which code is for the axle.
Old Jul 4, 2004 | 01:34 PM
3headedboris
Warranty Number: F10CK568339
W.B.: 114 (wheel base?)
Color: K
Model: F100
Body: D81
Trans: G
Axle: 12
Old Jul 4, 2004 | 01:39 PM
3headedboris
According to my shop manual, code 12 is 3.89-3.3M ratio and rating. Still not sure if it's a Dana Spicer or not.
Thanks.
Old Jul 5, 2004 | 07:15 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Is the rear cover welded or bolted on a 9 inch ford rear end has a hogs head
or a chunk, pumpkin if the gears load from the front its a 9 inch rear end .
Old Jul 5, 2004 | 11:30 PM
Rosati's Avatar
Rosati
Most likely, you have a Ford 9" as this was the most common rear end in trucks for the dealers. Since you did not list a DSO number, I am assuming the dealer did not special order ths truck so it would stand to reason it was a standard order truck.
Old Jul 6, 2004 | 02:53 AM
FordBoypete's Avatar
FordBoypete
A 223 CID I-6 with a 3 spd or 3spd OD in 61 thru 64 could well be a Dana rear axle, like Pro-Street says if the rear of the housing is held on with bolts that's what it is, but if if has a 3dr member that loads gom the front of the case then a 9" is what it is,
If I'm not mistaken both the Dana & FoMoCo 9" had 3.89:1 ratio available in 64.
FBp
shakedownshorty
Nov 15, 2014 07:05 PM
micguyver
Nov 11, 2009 09:00 PM
BergerFromage
Jun 11, 2005 01:32 PM
manyolcars
1983 - 2012 Ranger & B-Series
Dec 4, 2004 11:25 PM
Madmike33
Apr 22, 2004 01:10 PM
