Oil & Lubrication
View Poll Results: What would you recommend
Mobil 1 synthetic
31.88%
Royal Purple
5.00%
Red Line
2.19%
Castrol Syntec
7.50%
other
53.44%
Voters: 320. You may not vote on this poll
What oil do you use?
Old Jul 4, 2004 | 10:37 AM
1979f_100's Avatar
1979f_100
I need to do an oil change here pretty soon and was wondering what you guys would reccomend. It has 120637 miles on it running Mobil1 synthetic 10w-30 and a Fram oil filter.
Old Jul 4, 2004 | 10:58 AM
oppy's Avatar
oppy
Interesting that you only listed synthetics in the poll. I don't use them because I think they are a waste of money. Others here definitely have a different opinion. If you're stuck on syn, it'd be hard to beat the M1 for reputation.
I'm sure your choice of a Fram filter will get slammed also. Personally, I think they are fine.
Old Jul 4, 2004 | 11:02 AM
GrayRanger4x4's Avatar
GrayRanger4x4
Castrol 10W30-motorcraft oil filter.is what I use with no problems.If you have been useing Mobil 1 10W30{very good oil} I stay with it, but I would NOT use fram filters .THEY ARE JUNK!!
Old Jul 4, 2004 | 11:04 AM
1979f_100's Avatar
1979f_100
I plan replacing it with a K&N Performance Gold filter
Old Jul 4, 2004 | 11:08 AM
OdinVII's Avatar
OdinVII
I've been using the Castrol Syntec 10W-30 with a motorcraft filter for a little over a year now on my '97 4.6L with no complaints (129k miles)
I actually had the truck dyno'd back then with my normal Castrol then changed over to Syntec and dyno'd again... +3 horsepower
Seriously though, the Syntec has been good to me, so I plan to continue using it until my truck dies (since it's a Ford that'll be after me )
Old Jul 4, 2004 | 11:11 AM
goingfor3's Avatar
goingfor3
I use valvoline 5w30 and motorcraft filter on my 98 Expedition and i have 218,000 miles on it and have never had any problems. For your application a some 10w30 would be fine and the fram filter would be fine.
Old Jul 4, 2004 | 11:29 AM
666768F100owner's Avatar
666768F100owner
I go cheap, and it seems to work out pretty well.
Super Tech (Wal-Mart Brand, same people that make Havoline, I think) 20W50, and a Super Tech filter. Works great for me, and less than $10 investment.
Old Jul 4, 2004 | 11:41 AM
jschira's Avatar
jschira
Me too.
WOW!
Waaay too expensive. How many quarts?
Exxon SuperFlo or Shell 10w-30 on sale for $0.59/qt. + $2 SuperTech filter.
<$6. Where you getting $10?
Old Jul 4, 2004 | 12:04 PM
xltlariat87's Avatar
xltlariat87
motorcraft 10w30 or valvoline 10w30
Old Jul 4, 2004 | 03:02 PM
BlueOvalFitter's Avatar
BlueOvalFitter
First off,you are doing yourself a favor by not using that POS Fram oil filter! If it were me I would use the Mobil1.
Old Jul 4, 2004 | 03:27 PM
Bob Ayers's Avatar
Bob Ayers
Castrol GTX 5W30, and Motorcraft oil filter in my 3.0L FFV Ranger...I agree with everybody else, stay away from the Fram oil filter....
Old Jul 4, 2004 | 04:44 PM
Flash's Avatar
Flash
Depending on the application, Chevron Supreme, Havoline, and Mystic JT-8. I have no need for a synthetic, like most folks. I usually buy Motorcraft or Purolator filters but have used NAPA Gold as well. I would consider the Wally World filter as a last choice. It is better than most at filtering and construction is decent.
Old Jul 4, 2004 | 05:46 PM
RH F-350's Avatar
RH F-350
motorcraft 5w30 and motorcraft filters.
Old Jul 4, 2004 | 07:25 PM
homer4.2's Avatar
homer4.2
I use Valvoline SAE 5W-20 with an STP s3600 oil filter. What do you guys think about the two?
Old Jul 4, 2004 | 07:28 PM
johnsdiesel's Avatar
johnsdiesel
No synthetic here either. It's real hard to justify when it takes 14 quarts to change my oil. I'm not a big proponant of extended drain intervals in diesels which is why I change by the book. I usually use Shell Rotella T 15W 40, but have also used Delo 15W 40.
