The only heads that came with hardened seats was the D2TE-AA heads from a 1972 casting. I hear that not all of them were hardened but the vast majority were.
Take it to a machine shop and tell 'em you want hardened seats put in the exhaust. The intake doesn't need 'em, it runs much cooler. Of course if they're out of spec it'll need 'em.
and if i keep the old seats...any draw backs? Also when the valves where still in the head i put a straight edge across the top of the valve stems...they where uneven...do they grind them back to length?
keeping old seats is not good, if you did the unleaded gas will eat them away, unless you used lead additive everytime you filled the tank, in the long run, hardened seats is definetly the way to go.
Have a good look at your seats.....Constant pounding of the seat by the valve,over many years, actually does harden them.....Unleaded has been the only fuel available for quite a few years now....If the seats are in reasonable shape, hardened seats may not be required...A good macine shop will only sell you what you need...d44hd
Im thinking they may have already been done, they look in good shape..and the heads show signs of rebuild already, like sleeves in the intake guides for the valves. I was told stock would have NO sleeves?
I have learned that when i get an old truck most of the time the heads have already had one valvejob in there life time. Unfortunately ive ran accross alot that are not capable of being done anymore because of this too. My point is that it doesnt supprise me that if they have been done already. Maybe you can have them magnafluxed and just put new parts in them.
