1997 4.0 pinging final fixed
Old Jun 24, 2002 | 09:49 AM
Gstoughton's Avatar
Gstoughton
Post 1997 4.0 pinging final fixed
I just wanted to share that I finally resolved the pinging in my 97 4.0 OHV explorer. The solution was to take the upper intake manifold off and tighten the lower manifold bolts. Luckily it did the trick and I did not have to change the gasket. The bolt were pretty loose. The job took about 3 hours and only required a good socket set and wrenches.
Old Jun 26, 2002 | 06:58 AM
winfordr's Avatar
winfordr
Great info, thanks!
Winford
Old Sep 17, 2002 | 11:28 AM
emba129's Avatar
emba129
Can you inspect this before you take the upper intake off or is impossibble to get to.
Thanks
Chris
94 XLT with 4.0L
Old Sep 17, 2002 | 02:05 PM
mrshorty's Avatar
mrshorty
When I did this to my '92, I managed without removing the upper intake manifold. Took some creativity to get to a couple of the bolts, but most were easily accesible through the upper manifold.
Old Sep 17, 2002 | 04:45 PM
PROV811's Avatar
PROV811
