Towing with Windstar
Old Jul 5, 2004 | 05:35 AM
johnsdiesel's Avatar
johnsdiesel
Originally Posted by believer45
Check HERE to see a plug-and-play kit for the 99-2003 Windstar. At the price it is a fast, easy, pretty much fool proof way to hook up.
Similar kits and such are available at places like Wal-Mart.
I have used on several vehicles, no wires to cut, splice or tap into.
Dave / Believer
Looks like the safest way to hook it up with all the "computer stuff" in these engines now.
Old Jul 5, 2004 | 06:40 AM
SHERB145's Avatar
SHERB145
I'll look at ford first, but thanks for the suggestion! What about the "passes" on a transmission? I was looking for a cooler and it wanted to know how many "passes" I had? How do you find this out?
Old Jul 5, 2004 | 09:18 AM
FrankLee's Avatar
FrankLee
I have a '98 Windstar with the factory tow package. If your '00 is pre-wired for the towing package, there should be two connectors attached to the frame next to the spare on the left side. One connector is for the trailer lights and the other is for a brake circuit. Let me know if you need pix.
Old Jul 5, 2004 | 09:54 AM
SHERB145's Avatar
SHERB145
They changed the wiring after '99, it's inside and there is a computer hooked up. So I don't have one, and if I did it pobably wouldn't be there. Thanks for the input though!
To buy the harness from ford is $70 and it doesn't void the warranty. It's a little more than i figured, but it's worth it. Thanks for everyone's help! If you get any new info just post it, but I think that with your help I will buy the $90 hitch and $70 harness.
Old Jul 13, 2004 | 08:59 AM
fornarog's Avatar
fornarog
I have a 99 windstar with the 3.3L I just hooked up a hidden hitch Class III to it ($100 delivered) and also an aftermarket wiring harness ($50). The wiring is funky - it is computer controlled and you need to run a fused power line from your battery to the wiring harness to get everything to work properly.
I pulled a 4x8 utility trailer with plank sides loaded with vacation gear about 1200 miles total last week with no problem. The loaded trailer probably went about 900 lbs.
We didn't have any hills to contend with, but the acceleration into traffic was just ok.
Old Jul 27, 2004 | 01:20 PM
jqp's Avatar
jqp
The Windstars use a switched negative ground system... you have to have a magic little black box of relays or you'll smoke the computer.
JQP
Old Jul 28, 2004 | 11:42 AM
SHERB145's Avatar
SHERB145
My trip went fine. I wouldn't have been able to do it without ur help! Thanks!
