460 starter
Old Jul 3, 2004 | 07:30 PM
sparky0690's Avatar
sparky0690
460 starter
hey guys i just droped a 460 in my 66 trying to get it all together i put a new starter on the truck an when i turn it over a grinding sound happens at first it sounds like it cathes the flywheel and turns over slowly i had a friend years ago that had a truck that the same thing was going on but i never found out what his problem was now i dont know where he may be anyway this is a new starter and fly wheel as far as i could tell the new starter and fly wheel are exactly like the ones that come off someone please help me harley
Old Jul 4, 2004 | 08:17 AM
ol yeller's Avatar
ol yeller
Same
Mine did that on my 352. I had to shim the starter out about 1/16 with washers. Works fine now.
Old Jul 4, 2004 | 09:35 AM
FordBoypete's Avatar
FordBoypete
In 385 series engines starters are flywheel specific. You must run an A/T starter with an Automatic trans, and a Manual Shift starter with a manual shift trans set up.
THe ring gear depth is different. Changing nose does not help because A/T starter has a shorter armature shaft than a manual starter.
This problem also happens when an FE Flywheel is substituted for a 385 flywheel. Some say they shim starter to get right mesh. But I'd say get the correct starter for the flywheel and use the correct flywheel for the engne and avoid all the hassle.
FWIW, FoMoCo starters are engineered to fit into a machined out receiver lip, with the anti flex-torque plate in position. This lip holds the torque load when starting. Not seating in the machined receiver area transfers the twist to the bolts and they are not designed to hold that. . . . It could cause starter drive, nose piece, and shaft problems or lead to premature starter or flywhel failure.
GM shims their starters and look at all the problems GM Starters have all the time.
Just my 02 on this
FBp
Old Jul 5, 2004 | 07:32 PM
sparky0690's Avatar
sparky0690
thanks a lot fbp and ol yeller i sure appreciate yous guys help
