Does anyone know if Ford made a stock 8" rim for my 1994 XLT f-150, its the aluminium ones. my are 7" and would like an 8" for 31x10.5 tires and abit wider stance
They are 7.5" wide, not 8, which will take up to an 11.50" wide tire. However, that size tire is about 1/2" thinner than the recommended width, but if you run the air pressure a couple PSI lower you'll still get even tread wear. I have some 32/11.5s on those rims..so its ok.
does your 32/11.5 rub, that seems like a big tire for a stock height and a 7.5 rim,is your truck lifted?I have 32's on my 78 bronco, but there on 8.5 outlaw rims. the only thing I don't like about the stock rims is the offset, I want something alittle deeper dished, so the tire comes out aleast flush to the body, thats why I was wondering if theses stock rims came any wider than 7.5
