Offroad & 4x4
bigger then 9"
Old Jul 2, 2004 | 02:11 PM
mjl351w's Avatar
mjl351w
bigger then 9"
well for some reason i hate having the normal everyday lift junk so i was wondering if any of you may know where i could find a place that will make me 14" lift coil springs , i have 9" s but then i have to add a body lift to clear the 44's i want to run. so far all i have found as lazy @*$ companies that will either make drop coils or offer only up to the 9" ones i already have.
thanks
78 bronco Dana 60 front and rear,Np435,Np 205 will have 390 and i would like to have coil srings i allready went and set the axle up for it, 44tsl's one day
Old Jul 2, 2004 | 03:25 PM
95-F-350-4x4's Avatar
95-F-350-4x4
i would just cut away with a sawzall rather than finding coils that high. you probably can't find them that high because of safety reasons.
Old Jul 2, 2004 | 05:15 PM
ramboss429's Avatar
ramboss429
I'd have to agree with '95 on this one.
You could switch over to leaf springs if you are really wanting 14" of lift.
Old Jul 2, 2004 | 08:39 PM
DasaniHo's Avatar
DasaniHo
with 9 inche sof lift you can clear 44's just fine...if you offroad it youll need o trim a little off the bottom parts of the frnt fenders
Old Jul 14, 2004 | 10:07 PM
mjl351w's Avatar
mjl351w
OH well i allready have one with the saw-zall lift why not have 2 ....thanks for the Input fella's
Old Jul 14, 2004 | 10:24 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Here's a little trick a friend of mine and I did to his 78 P/U. Go to a wrecking yard and get a pair of coil buckets off of the same year rig then cut 3 inches out of them and weld them back together (using plate to join the mis-match) then bolt on the 'new' buckets and "VOILA!!" Three more inches for next to nothing. He had the same problem...9 inch coils and no one made taller ones.
Cody
