I have a class A motorhome on a 2000 F53 Ford chassis, V10.
Recently at startup I had the following problem. Flashing off light on overdrive (overdrive still worked), no cruise control, no speedometer and no odometer movement. Drove the coach about 50 miles, stopped , shut engine off for about 15 minutes. On startup every thing worked as normal. Any help would be appreciated.
Reason: added info
