False....but.....FMC in their infinite wisdom severely damps the response of the gauge so by the time it moves very far from the middle the temperature has increased a bunch.
Same as the Transmission temperature gauge.
AutoJim (an OEM cooling engineer) has explained the operation of gauges very well.
Sorry if this hurts anyone's feelings, but most people are stupid. When they see the needle on a gauge move too much, they think that there is a problem. AutoJim has personal experience with this while at DCX. Replaced 1000s of perfectly good t-stats under warranty because on really hot days, the needle would move up from the bottom middle of the gauge to the top middle of the gauge. Maybe the width of the needle. Everyone filed warranty claims that there t-stat wasn't working right and that the engine was running too hot. DCX tested a bunch of the t-stats and found that they were working perfectly normally. Finally, DCX "dumbed up" the gauge and the warranty calims dropped to almost zero. No change in the t-stat.
So . . . .
The OEMs neuter the needle so that it only swings when you are outside the specified temp/pressure range. When you are within specs, the needle goes to the middle of the gauge and stays there. This cuts waaaaay down on warranty claims.
So . . . .
I don't like it, but I don't blame the OEMs.
Same reasoning with making the oil pressure register normal at anything over 7 PSI. People were continually bringing in their car/truck for low oil pressure so Ford solved it some years back.
Yep.
People want reassurance, not detailed information.
The oil pressure gauge, on the other hand, is a worthless piece of junk. An idiot light in the form of a gauge. See page 56 of the 6.0L Bible. In fact it's so worthless, it's not even connected to the PCM in any way, shape or form.
