Speedo
Huey
"They gave me a speedo that screwed into the tranny and it didn't work". I don't quite understand that statement, but I assume you mean you bought a speedometer cable and housing assembly and it didn't work.
If your truck has the removable nylon speedometer gear (not sure what year your truck is or when they started using the nylon gears), you can remove and inspect it. They are usually held in place with a small 1/4 inch bolt and are sealed with a rubber O-ring. A small amount of fluid will come out so be prepared for that. If the cable and the housing are new and you know the speedometer head is okay, the nylon gear is about all that's left that could be bad unless the gear in the transmission itself that turns the nylon gear is bad and they seldom go bad...
Vern
If yours IS a nylon speedo gear and you have the old one, make SURE you get the same spline-count replacement. They are usually color-coded. Also make sure the "twist" goes in the same direction as the original you're replacing. If you know the year and vehicle the tranny is out of, the Ford dealership guys or the NAPA guys should be able to reference the exact speedo gear you need for your tranny.
Keep us posted and we'll keep checking this thread...
Good luck,
Butch n Me
