expedition shift indicator
Old Jul 1, 2004 | 11:46 AM
mountainman101's Avatar
mountainman101
shift indicator off n is reverse d is nutreal 2 is drive how do i adjustit is off you have to have it go on place to the left
Old Jul 1, 2004 | 12:04 PM
tyger25's Avatar
tyger25
The indicator is attached to the shift lever by a guide wire. You have to take the cluster out to adjust the indicator.
Old Jul 1, 2004 | 12:36 PM
Iceman8984's Avatar
Iceman8984
The adjustment for the indicator is under the dash. More than likely the little plastic holder for the adjuster has broken. You can replace the holder or put the adjuster through the part that remains and adjust it to read properly. You can get at it by removing the panel in fron of your knees. You don't need to remove the cluster.
rjniles
2009 - 2014 F150
Nov 30, 2016 08:58 PM
trophy_fish
Apr 5, 2016 08:05 PM
Shadowrider123
Feb 27, 2016 09:48 PM
Drive-By
2004 - 2008 F150
Dec 5, 2008 11:20 PM
