Question for the pros
Old Jun 30, 2004 | 09:31 PM
AF Mezkin's Avatar
AF Mezkin
This question is for the professional painters and bodyworkers. I have a 03 Expy XLT with the lower exterior gray textured cladding. I have been thinking about painting them to match the body color. Is there anything in the paint and body world that fills in or smooths out the textured surface of the cladding before paint is applied? And if not is there a good adhesive promoter that will reduce or eliminate the possibility of the paint from chipping, cracking, or flaking the first time it gets bumped or I take it to the car wash?
Old Jul 13, 2004 | 03:12 PM
sierra5.3's Avatar
sierra5.3
My advice is to scuff the plastic with a red scuff pad, clean with a good plastic prep and then prime with a plastic primer and then paint and clear with three good coats of clear. I know this sounds like a long procedure, but it is well worth it and it lasts. Last step is to wetsand entire surface smoothe with 600 grit paper and reclear. You may need to put one more coat of paint before clear depending on how much you sand. I have done many trucks like this and it will last forever. And look great
Old Jul 14, 2004 | 07:58 AM
fordpilot's Avatar
fordpilot
I would try to identify the type of substrate. Then see if your
paint manufacturer has specs on coating that material. Most
of them will have you add a plasticiser. It takes about twice
as much work as you would normally think.
Old Jul 18, 2004 | 06:22 PM
AF Mezkin's Avatar
AF Mezkin
Thanks for the info, I'm might get some price quots on painting verses swaping over to E/b cladding.
Richard2212
Paint & Bodywork
Mar 12, 2016 09:03 PM
hivoltj
Sep 2, 2011 11:35 AM
jond73
Paint & Bodywork
Jun 28, 2006 12:58 AM
SLT72187
49
Feb 16, 2005 02:30 PM
2003expXLT
Nov 4, 2003 05:38 PM
